cep10189
Sep 24, 2021Guide
R6230 GUI log on requiring me to create a Netgear account to proceed
I have done this dozens of times with previous models.
I go through the manual configuration, I put all the settings how I want them.
As soon as I connect the Internet port I am unable to log on. It keeps redirecting me to setup a Netgear account.
I have updated the firmware.
Does not happen on the R6220 or WNR2000 models.
Why do I require a Netgear account to log on to my local device?
Device: R6230, FW Ver:1.1.0.110_1.01, Static Internet IP, Static DNS, Use as DHCP, Wireless Network: On, Guest Network: Off
You don't.
What are you doing when this happens?
How are you approaching the router?
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.- cep10189Guide
I am attempting to log on to the device using Firefox or Chrome or Edge and the LAN IP address which is the Gateway address my Windows laptop is assigned. It doesn't matter if I am on the Wireless Network or directly connected to one of the LAN Ports.
During the manual setup of the R6230, I connect using Firefox and the LAN IP address, so I know it works. Once I connect the Internet Port it starts redirecting me to the screen shot I have attached. I create an account, sign on and then I can access the R6230.
I don't understand why it is making me create this account. It makes it seem like it is tied into Netgear now, and that doesn't seem right.
I don't get that bit. Why are you using the Gateway address your Windows laptop is assigned? Assigned by what?
Start at the beginning.
Your subject says "GUI log on".
If you want to login to the browser graphical user interface (GUI). There are two ways in:
Is that what you are doing?
If you try to access the address of your Windows laptop, then you are trying to access the laptop, not the router.
What does "connect the Internet Port" mean?
This is all very confusing.
In your first message you say "Static Internet IP". Is that because your Internet service provider has allocated you to a particular IP address on the Internet? As the manual says "this setting is rare". Or is this some other static address on your local network?
What is the modem, if there is one, in front of thbis router?
