sb801
Apr 29, 2024Aspirant
R6230 Intermittent / Failing Internet Connection
I have a Netgear ac1200 model R6230 router and, starting last night, I was not able to successfully gain a consistent internet connection through the router. I had no prior issues since upgrading th...
Apr 30, 2024Guru - Experienced User
Try a device hardwired to the router. We need to figure out if its an inconsistent wireless issue, if the whole router is inconsistent, or if it has something to do with the connection to modem
sb801
May 01, 2024Aspirant
I tried again with a hardwired device to the router and then to the modem. Both are working the same which is what I did not think was happening several days ago -- basically it works fine after a power cycle for 4 minutes and then the connection slows significantly or fails. As a result, I am now back to working with my internet provider to determine the issue. Thanks for the help.
