Robshi
Mar 23, 2023Aspirant
R6230 Internet disconnecting on 30 minute intervals
I've been having this issue where my internet cuts out on 30 minute intervals for about 5-10 seconds. I'm using an ARRIS SURFboard SB6190 for my modem plugged into my AC1200 WiFi Router (R6230) rout...
- Mar 24, 2023
So I have an update. My buddy's solution to reserve my PC's IP seems to have worked.
I was playing an online game while my router logged the "internet connected" message and experienced no disruption to my connection to the game server.
I'll just go ahead and reserve all the IPs for the devices my household uses and call it a day.
michaelkenward
Mar 23, 2023Guru - Experienced User
Robshi wrote:
Thanks for the reply.
It's version V1.1.0.114_1.0.1 according to my routerlogin.net page. I've run the "update firmware" button in there and it says I have the latest.
That's where the trouble can start. The check misses things.
The only place to get a reliable answer is here:
Support | NETGEAR
That page will also have software, firmware and drivers for your device, if they exist. In your case, the check is correct. But don't rely on it to stay that way.
Robshi
Ok good to know. My buddy is having me try assigning a static local IP to my PC. Said it worked for another user he found.
Any other thoughts of something I could try to address my issue?
- michaelkenwardMar 23, 2023Guru - Experienced User
Cable modem experts around here may be able to help. Never trust what an ISP says. The ISP says "your hardware" but it may just be passing the buck.
My question is around the cause of these dropouts.
Timed disconnects aren't something that crops up here as a regular problem. So I would try some other diagnostics.
ISPs have a habit of resetting connections as they see fit. (Look up "lease time".) But that should show up in the router's logs.
I don't think it applies here, but some network devices suffer from "sleep mode" kicking in on Windows PCs. USB devices like to do that to save energy.
- RobshiMar 24, 2023Aspirant
