manicmint367
Nov 23, 2020Aspirant
R6230 not able to reset password
antinode
Nov 23, 2020Guru
"not able"? Don't have a pointed stick, or what?
_Which_ "password"?
"not able" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Types of
Logins" and "Factory Settings". Further reading might not hurt, either.
- manicmint367Nov 23, 2020Aspirant
antinode wrote:> R6230 not able to reset password
_Which_ "password"?
descriptions or interpretations.Visit http://netgear.com/support , put in your model number, and look
