Mariannee's avatar
Mariannee
Follower
Jun 22, 2021
R6230 not connecting
R6230 not connecting to internet at all, purchased April 2019 can it go bad so quickly?  Seems like I only get about 2 years out of past few purchases of  Netgear.  Is there something better that someone can recommend that's not too terribly expensive?
  • > R6230 not connecting to internet at all, [...]
       Firmware version?  Connected to what?
       "not connecting to internet at all" is not a useful problem
    description.  It does not say what you did.  It does not say what
    happened when you did it.  As usual, showing actual actions (commands)
    with their actual results (error messages, LED indicators, ...) can be
    more helpful than vague descriptions or interpretations.
    > [...] purchased April 2019 can it go bad so quickly? [...]
       Sure, it could.  Did it?  With a problem description like "go bad",
    who could tell?
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for the
    LED descriptions, "Troubleshoot", and "Reset".  Further reading might
    not hurt, either.
    > [...] Is there something better that someone can recommend that's not
       This radical concept sometimes helps some people:
          https://en.wikipedia.org/wiki/RTFM
    It's very cheap, and occasionally effective.
1 Reply
    who could tell?
    not hurt, either.
