animeniac
Apr 13, 2022Aspirant
r6230 not getting full speed
i bought a used r6230 because it is supposed to be gigabit speed so i thought it would improve my wifi speed but it's the same as my r6020 and only gives around 94 mbps down and 10 up when i pay for ...
- Apr 14, 2022
Good to hear. CAT6 would be recommended.
Enjoy. 📡
Apr 13, 2022Guru - Experienced User
You'll never see anything near 900Mpbs on 2.4 or 5Ghz wifi. Most devices top out at 300Mpbs to 500Mpbs depending on router model and device support and design.
You may see near 900Mpbs thru the R6230 with a ethernet connected PC with 1000Mpbs connection rate, however being a older generation router, wired may not see that either.
IF you want to see Gg speeds on wifi, you'll need a AX wireless mode supporting router.
animeniac
so i'm only going to get 100 mbps and nothing even remotely close to 250
