vt460's avatar
vt460
R6230 not requiring password to login
My R6230 is in Wireless Access Point mode, connected by Ethernet cable to a Nighthawk X4S. I want to be able to mange the R6230 remotely, which is apparently not an option in Wireless Access Point mo...
  • vt460's avatar
    vt460
    Sep 25, 2018
    The setup I was hoping for would allow the following
      - X4S R7800 login via LAN IP from local network - this works of course, with caveat 1 below
      - X4S R7800 login via WAN IP (remote management) - this works, with caveat 1 below
      - AC1200 R6230 login via LAN IP from local network - this works of course, with caveat 2 below
      - AC1200 R6230 login via X4S WAN IP forwarded with PAT to R6230 LAN IP - this works, with caveats 2 and 3 below
    wrt my original post, I was using the same admin password on both routers, and I think ultimately this led to some authentication caching problems in the browser - I've found that if I'm very careful to always Logout I can't recreate the problem of a password not being required, regardless of how I reach the R6230
    Based on the discussion above and further consideration, I've realized this would be terribly insecure:
    caveat 1: local and remote management via https with the self signed R7800 certificate is not secure
    caveat 2: https is not supported on the R6230 LAN IP at all, regardless of local or forwarded connection
    caveat 3: if I login to the R6230 via the same WAN address as the R7800 I get a warning about another active login, which is wrong, and I think is related to my earlier belief that passwords were not being required because of auth caching problems and browser cookies
    Oh well, lessons learned, hopefully someday Netgear will add proper certificates with proper TLS support for admin login
    thanks to everyone who pitched in!
