poslab's avatar
poslab
R6230 only getting below 200M speed
I bought R6230 two years ago, my internet speed got upgrade recently to 900M. From the setting of R6230, 5G is up to 867M.    I connected a cable to R6230, it can get 600M, that means my Modem work...
  • Kitsap's avatar
    Kitsap
    Aug 27, 2022
    The Ookla application is installed from the Play Store.  It is not part of a GUI or a web address where you use a browser.
    On a good day for Wi-Fi, the 2.4 GHz band will deliver 125+ Mbps to average devices.  Similarly, the 5 GHz band will deliver 300+ Mbps to average devices.  The numbers in the router configuration page are theoretical link capacity.  They are not real world actual.
    Make sure the devices you are running the tests from have the most recent device drivers installed.
    Next you could experiment with different channel numbers in the bands.  Disable Auto channel selection and select channel 11 in the 2.4 GHz band and channel 48 in the 5 GHz band.
