stanward
Jan 05, 2023Follower
R6230 Slow Connection Speeds, reboots fixes temporarily
Hello, I have been fighting over this R6230 for quite some time. I have a PC connected to it with Cat 5E cable. And internet speed tests will show a max of 80Mbps download. If I Reboot the R62...
michaelkenward
Jan 05, 2023Guru - Experienced User
Tested how?
It might help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
