Rylen
Nov 19, 2024Aspirant
R6230 sometimes does not connect ALL WiFi devices to internet
I've a R6230, Firmware: V1.1.0.114_1.0.1. My setup: this gadget is my gateway ... address 1.1. DHCP is off. WiFi 2.4 and 5 are on. Guest networks off. It connects to my provider's modem & to o...
Rylen
There shouldn't be anything else. I'll see if I can find a good network listener to search for something else that wants to provide DHCP.
Spectrum provides me with a Hitron CGNM-2250. Looking at Internet Port -- Connection Status, there is a DHCP server. But unless I'm mixed up, that's for getting my internet facing address and should not do anything for access on my side of the gateway.
michaelkenward
Nov 20, 2024Guru - Experienced User
That is a modem/router.
CGNM-2250 Cable Modem Router - Hitron Americas
Two routers on your network can cause headaches. For example, you can end up with local problems with addresses on your network. Among other things, the other router can misdirect traffic to addresses that the Netgear router usually handles, such as routerlogin.net or the usual default IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point (AP) with a wired connection to the main router. Netgear advises this, as does just about every site you will visit.
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router.
hitron cgnm-2250 bridge mode - Google Search
Your call.
Just another user with time on their hands.
- RylenNov 20, 2024Aspirant
Spent some time learning about Wireshark and then tracked down a 2nd DHCP server. The cable modem has been absolved. The info about setting up as an AP should be useful when I rework the 2nd DHCP.
Thanks,
Rylen
