madpsychologist
May 03, 2021Tutor
R6230 Wireless Repeater Function: IP address option
I'm trying to set up my Netgear router as a wireless repeater, but the "Wireless Repeater IP Address" field confuses me. What should I fill into it? Isn't that just the router's IP address, which is ...
- May 04, 2021
someone made a fairly nice video walking through setting it up.
https://www.youtube.com/watch?v=6YhVzhESUy4
there's also the guide.
https://kb.netgear.com/24108/How-do-I-enable-the-extender-mode-feature-on-my-Nighthawk-router
May 04, 2021Guru - Experienced User
- madpsychologistMay 04, 2021Tutor
The video showed entering the address 192.168.1.1 and I couldn't find the sticker indicated by the print tutorial. :(
Never mind; found it! Many thanks!
- plemansMay 05, 2021Guru - Experienced User
Glad you got it working! If you mark it solved, it might help the next person
