jjriv's avatar
jjriv
Follower
Mar 16, 2020
R6230 won't upgrade to latest firmware
I keep getting emails from NetGear telling me I need to upgrade my firmware to Latest firmware version: v1.1.0.92 I am current running V1.1.0.86_1.0.1 When I try to check for a new version from the...
  • antinode's avatar
    Mar 16, 2020
    > What should I do?
       Visit http://netgear.com/support , put in your model number, and look
    for Downloads.  (For older versions, under Firmware and Software
    Downloads, look for "View Previous Versions".)  Find the kit(s).
    Download the kit(s) you want.  Read the "Release Notes" file for
    instructions.
