gregd96067
Aug 04, 2023Aspirant
R6250 browser interface
In my home I have an Arris S33 modem, a Trendnet teg-s24g gigabit switch, and a Netgear R6250 Router. https://www.surfboard.com/products/cable-modems/s33/ https://www.trendnet.com/products/produ...
- Aug 08, 2023
I never resolved the issue. My cable provider sent out a tech, that didn't help. Reset the router more than once, power-cycled all the gear, triggered multiple hardware resets. Nothing helped. I ended up purchasing a new router rather than continuing to fight this issue.
Thanks for the assist folks.
gregd96067
The URL routerlogin.net automatically redirects to HTTPS. I cannot influence that.
Entering 192.168.1.1 into Chrome or Firefox, there is no HTTPS being referenced. Firefox returns this:
The connection has timed out
The server at 192.168.1.1 is taking too long to respond.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer’s network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the web.
Aug 04, 2023Guru - Experienced User
With the router disconnected from the ISP modem, press the reset button in back for 10 seconds then release. After the router comes to partial ready, can you access 192.168.1.1 with a wired PC and web browser here?
