gregd96067
Aug 04, 2023Aspirant
R6250 browser interface
In my home I have an Arris S33 modem, a Trendnet teg-s24g gigabit switch, and a Netgear R6250 Router. https://www.surfboard.com/products/cable-modems/s33/ https://www.trendnet.com/products/produ...
- Aug 08, 2023
I never resolved the issue. My cable provider sent out a tech, that didn't help. Reset the router more than once, power-cycled all the gear, triggered multiple hardware resets. Nothing helped. I ended up purchasing a new router rather than continuing to fight this issue.
Thanks for the assist folks.
gregd96067
Aug 05, 2023Aspirant
ok, I will follow the steps you describe and check in with you a bit later. It sounds like the point you made at the end of your response is that I'm attempting to do something that is not possible? I can log in to the modem's interface, and was hoping to log in to the router as well, but I think you are stating that this is not possible. Confirm that please?
What is unfortunate is that when I started all of this, the issue was that my phone and television would not connect to the Wi-Fi. I contacted support for Vyve, my ISP, and somehow a reset that she performed remotely resulted in my being able to connect to Wi-Fi. But with that working, I then tried to follow the above instructions and that knocked down my Wi-Fi connection again. I reached the support tech again yesterday afternoon and her efforts to reset the modem were not successful in terms of getting the router to play nice again.
So at this point I have a service call scheduled for Tuesday, and I'm hoping that if possible, powering everything down (per your direction) will at least get Wi-Fi to talk again.
michaelkenward
Aug 05, 2023Guru - Experienced User
That is my understanding, based on my use of a separate standalone DSL modem. Maybe cable modems are different.
If the router is in the IP range 191.168.1.1 to 192.168.255.255, then 191.168.0.1 is outside that address range. At least, it can't reach my modem. I have to connect to the modem without getting the router involved.
Looking at the manual for your modem, it claims that the default IP address is191.168.100.1.
- gregd96067Aug 08, 2023Aspirant
