junyan2000
Jan 16, 2022Tutor
R6250 Face plate affects cpu temperature
Today I took off the cover (face plate) of my Netgear R6250, and the cpu temperature dropped 8 degrees, from 79C to 71C. What can be the explanation? The router is already full of holes on the ba...
- Feb 22, 2022
Seems a bit hot. From my recall (and the devices I currently have on) I sit around 50-60C.
that device might be on its way out as temperature is the death of electronics
junyan2000
Feb 21, 2022Tutor
Thanks for the explanation.
Today the R6250 is running at 85C with cover on. Is this normal temperature, or is this cause for concern?
The increase is probably due to warmer room temperature. So in summer the router may get even hotter, perhaps reaching 90C.
Feb 22, 2022Guru - Experienced User
