dicey217
Aug 09, 2017Aspirant
R6250 firmware update and now dropping 2.4 connections and wired connections every 10 min
Was getting super slow speeds, so I checked and updated the firmware to v1.0.4.12_10.1.15. Since then my 2.4 and wired connections keep dropping. I cannot get it reconnected unless I reset the rout...
- Aug 15, 2017
Hi dicey217,
1. When you say reset, are you referring to pressing the small reset button in the back of the router?
2. If yes, please try re-flashing the firmware then do a factory reset. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
