papadeltasierr1
Apr 07, 2026Initiate
R6250 in WAN bridging mode?
I want to put an R6250 into WAN (not WiFi) bridging mode - is this possible? I want to be able to do this: ADSL router LAN port === R6250 WAN port The ADSL router provides all NAT and DHCP functio...
papadeltasierr1
Thanks - just found this myself :-).
The process is:
- "Advanced tab"
- "Advanced Setup"
- "Wireless AP"
- "Apply"
- "Wireless AP"
You will want to let your downstream router assign the R6250 an IP address. I used "Reserved/Static DHCP" on y downstream router to ensure that the R6250 always gets the same address assigned.
Apr 07, 2026Guru - Experienced User
Can set Static IP for the AP mode as well.
Enjoy.
