CDataBHM
Jul 04, 2019Aspirant
R6250 Intermittent WIFI Connection
greetings....connecting via cable with my laptop to the R6250 is fine. But the wifi is going up/down constantly. It doesn't stay up for more than a second or so then goes out for a second or so and ...
- Jul 04, 2019
Actually we can close this one. So I compared with another device - and it stayed locked on the wifi and was not going up/down .....turns out it was a different wifi network. there are 2 - the one with the problem was on "OurNetwork" while the other device was on "OurNetwork-5Ghz"..... so simply changed device 1 to use the other network connection and all is fine.
CDataBHM
how does one know the firmware version?
given we've had the device ~5 yrs a power voltage/amp issue is perplexing......
does the reset wipe out the password too?
CDataBHM
