wfps6296's avatar
wfps6296
R6250 router map shows TV but Samsung TV cannot find wireless connection
it worked until about a week ago, other devices working - TV set up searches for wireless but finds nothing
  • DexterJB's avatar
    DexterJB
    Mar 22, 2016
    Hi @wfps6296,
    The TV will only show up on the network map if it was able to successfully connect to the network. If you try to scan for available wireless network on the TV and it does not detect anything then I recommend contacting the TV manufacturer.
    Dexter
    Community Team
