2321kamykom
Apr 06, 2019Aspirant
R6250 Wireless Bridge
Can I bridge a NETGEAR R6250-100NAS Router to a NETGEAR R6250-200NAS Router?
- Apr 06, 2019
I
2321kamykom wrote:
I am trying to do this: https://kb.netgear.com/20831/How-to-set-up-Bridge-mode-on-R6300-R6250-R6200.
Thus, can I set up "Bridge Mode" between a NETGEAR R6250-100NAS Router and a NETGEAR R6250-200NAS Router? They're the same model but different versions.
Thanks
If you look at the sidebar on the right side that shows what devices it applies to, it shows the article applies to the R6250 and R6250v2. It'd be worth trying. Worst case scenario is just resetting them. the manual antinode refers to would be beneficial too :)
antinode
Apr 06, 2019Guru
> Can I bridge a NETGEAR R6250-100NAS Router [...]
"R6250[v1]".
> [...] to a NETGEAR R6250-200NAS Router?
"R6250v2".
That depends on what "bridge this to that" means to you. It might
help if you explained exactly what you're trying to do, in plain
language (without using ambiguous terms like "bridge").
Possibly useful: Visit http://netgear.com/support , put in your model
number(s), and look for Documentation. Get the User Manual(s). Look
for "access point".
2321kamykom
Thanks
- plemansApr 06, 2019Guru - Experienced User
I
Thanks
