sbhall4060
Aug 14, 2017Follower
R6250 Wireless Router cuts my hardwired internet connection speeds in half
R6250 - I don't understand... I have verfied (by provider and various speed testes) 100 MBPS when I make a hard wired connection from my modem to my desktop. Then when I switch over to wireless I am ...
- Aug 17, 2017
Hi sbhall4060,
1. What is the firmware version of the router?
2. Have you tried resetting the router?
3. Have you tried using a different cable to connect the router to the modem?
4. You can try changing the MTU values. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/19863
http://kb.netgear.com/app/answers/detail/a_id/25675
Dexter
Community Team
DexterJB
Aug 17, 2017NETGEAR Moderator
Hi sbhall4060,
Dexter
Community Team
DexterJB
Aug 21, 2017NETGEAR Moderator
Hi sbhall4060,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
