Klthoma86's avatar
Klthoma86
Follower
Dec 28, 2017
R6250
Why can't I pause internet for any device??
  • Hi Klthoma86,
    1. What is the firmware version of the router?
    2. Are you referring to the "Pause Internet" feature on the Genie app?
    3. Are you using Android or iOS?
    4. Have you tried using another device (Android or iOS)?
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Klthoma86,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Klthoma86,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
