AyanSett
Jul 08, 2020Tutor
R6260 drops World of Warships in every 5 to 10 minutes
Hello, While using ethernet port and trying to play World of Warships internet connection drops in every 5 to 10 minutes. When connected through Wifi and playing World of Warships i didn't face any ...
- Jul 12, 2020
Hello,
It's looks like the issue is mostly resolved. Today i played World of Warships multiple matches connected through ethernet. But i didn't face any connection dropout.
Solution I found till now:
Ethernet Link speed was initially set to Auto, i changed it to 1GBPS. After that i didn't face any connection drop out.
Ayan
AyanSett
Jul 09, 2020Tutor
Hello,
1. What modem are you using? - I am using R6260 Router, which I purchase recently
2. Firmware on the router? - Router Firmware Version V1.1.0.66_1.0.1
3. Have you tried changing cables and ports on the router that you use? - Yes
4. Any switches in line? - No
5. Are you using qos or any other traffic monitoring setup on the router (qos, traffic monitoring, parental controls, armor, etc. ) - No (Just configure the internet)
I already tested on other router World of Warships working fine through ethernet as well as from Wifi.
Ayan
Jul 09, 2020Guru - Experienced User
AyanSett wrote:Hello,
1. What modem are you using? - I am using R6260 Router, which I purchase recently-----That's the router. Not the modem/gateway. What is the router connecting to?
If you just bought it, you do get 90 days of free support (from date of purchase) from netgear. You can click "mynetgear" at the top, register an account, and then the device. From there you can contact support.
You can also try downgrading the firmware. Your 1.1.0.66 is newer than the current version on the server. maybe its got a few issues.
