AyanSett
Jul 08, 2020Tutor
R6260 drops World of Warships in every 5 to 10 minutes
Hello, While using ethernet port and trying to play World of Warships internet connection drops in every 5 to 10 minutes. When connected through Wifi and playing World of Warships i didn't face any ...
- Jul 12, 2020
Hello,
It's looks like the issue is mostly resolved. Today i played World of Warships multiple matches connected through ethernet. But i didn't face any connection dropout.
Solution I found till now:
Ethernet Link speed was initially set to Auto, i changed it to 1GBPS. After that i didn't face any connection drop out.
Ayan
AyanSett
Jul 09, 2020Tutor
Hello,
My Internet connection directly comes to R6260 modem on the yellow color Ethernet port.
I recently upgrade the firmware version, on the previous version i am also facing this issue.
Ayan
Jul 09, 2020Guru - Experienced User
And whats on the other end of that ethernet cord? whats supplying you with internet?
- AyanSettJul 09, 2020Tutor
Hello,
Thank for your reply.
Other end directly comes goes to optical fiber ethernet switch.
I believe if the issue with the switch or my ISP provider then I face similar problem with the other games too. (i.e. Players Unknown Battleground, Call of Duty - Warzone, Counter Strike, Warthunder). I only facing this issue with the game World of Warships when i connect internet through Ethernet. I didn't facing any issue while i connect internet through WiFi.
I also configured my internet on my spare single band Dlink Router and I didn't face any kind of issue while playing World of Warships when connect internet through Ethernet.
I am giving you the link for your reference, the exact issue which i am facing with World of Warships.
Ayan
