AyanSett
Jul 08, 2020Tutor
R6260 drops World of Warships in every 5 to 10 minutes
Hello, While using ethernet port and trying to play World of Warships internet connection drops in every 5 to 10 minutes. When connected through Wifi and playing World of Warships i didn't face any ...
- Jul 12, 2020
Hello,
It's looks like the issue is mostly resolved. Today i played World of Warships multiple matches connected through ethernet. But i didn't face any connection dropout.
Solution I found till now:
Ethernet Link speed was initially set to Auto, i changed it to 1GBPS. After that i didn't face any connection drop out.
Ayan
Jul 11, 2020Guru - Experienced User
A couple things to try.
enable the ipv6 setting.
Qos. usually we have people disable it but worth try it enabled
AyanSett
Jul 12, 2020Tutor
Hello,
Ayan
- AyanSettJul 17, 2020Tutor
Hello,
Connection is stable now. Please close this topic.
Thanks for your help and sugession to resolve the issue.
Ayan
