youngnake
Mar 25, 2020Aspirant
R6260 Firmware reinstall
After turning it on my router's power light perpetually blinks green and stopped working completely. After doing some research it looks like it got bricked during a firmware update. After trying ever...
- Mar 25, 2020
Try using these instructions.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
also make sure you're hardwired into a lan port on router for this.
and make sure tftp is enabled within windows.
https://www.thewindowsclub.com/enable-tftp-windows-10
Mar 25, 2020Guru - Experienced User
youngnake
I'm starting to think that I don't know what ip address to use for the [router ip] during the cmd prompt. I tried both 192.168.1.1 and 192.168.1.10 and both said "connect request failed". How do I definitively find the correct ip address to put there?
- plemansMar 25, 2020Guru - Experienced User
Try watching this video. They walk you through tftp on an extender but the procedure is the same for a router.
- antinodeMar 25, 2020Guru
> 192.168.1.10 [...]The default LAN IP address of the router is "192.168.1.1".
The IP address of your computer's Ethernet interface should be
"192.168.1.10" (or similar).If you're trying to talk to the router (using TFTP), then you specify
the _router's_ IP address in the TFTP command.> [...] "connect request failed".
If the router is sufficiently crippled, then it may not be running
its TFTP server.
> and stopped working completely. [...]So now it just looks dead, or what?
> [...] https://kb.netgear.com/19841
Seriously old.
- skatenatoApr 10, 2020Aspirant
I have the same issue, did you find a solution?
