cw8jwh
Nov 16, 2023Follower
R6260 future Firmware update
For the next planned firmware upgrade, would you please enable ( if technically possible ) the router to use DNS over HTTPS for connected devices, as well as increased reliability in maintaining...
Nov 17, 2023Guru - Experienced User
I was going to agree that that router is a pretty old/low performing device.
Doubtful how much time/resources netgear is going to devote to it.
If you're needing additional specs, I'd look at upgrading or trying 3rd party firmware (if there is for that router)
- michaelkenwardNov 17, 2023Guru - Experienced User
It is the old "you get what you pay for" mantra.
Those R6### routers were always budget devices. Some even had 100 Mbps LAN well into the 2010s.I have a feeling that these routers were too lame to attract the attention of the firmware hackers.
