PhilJay
Oct 29, 2024Aspirant
R6260 No way to disable wifi
Hi, I've had the R6260 from new and for the first time need to disable the wifi broadcast. I've gone to the ADVANCED -> Wireless Setup menu (screenshot below) on my R6260 but there doesn't seem to b...
- Oct 29, 2024
Start at step #4 in the 2nd picture you posted. Your first post is on the basic tab, when you should be on the Advanced Tab to navigate from there.
Oct 29, 2024Guru - Experienced User
- PhilJayOct 29, 2024Aspirant
Awesome thank you. I hadn't noticed there was an "Advanced Advanced Setup" as well as an "Advanced Setup".
