PhilJay's avatar
PhilJay
R6260 No way to disable wifi
Hi, I've had the R6260 from new and for the first time need to disable the wifi broadcast.  I've gone to the ADVANCED -> Wireless Setup menu (screenshot below) on my R6260 but there doesn't seem to b...
  • FURRYe38's avatar
    Oct 29, 2024
    Start at step #4 in the 2nd picture you posted. Your first post is on the basic tab, when you should be on the Advanced Tab to navigate from there.
