Angelo22
Mar 19, 2022Aspirant
R6260 WIFI Latency/Packet Loss Issue
Hello, So I purchased a Netgear R6260 router last year around September and ever since then I've had a problem with the WIFI. So the problem only happens while connected to the WIFI (both 2.4G...
Angelo22
Mar 25, 2022Aspirant
I used to have a cheaper Netgear router years ago and it was amazing. I had no issues with it for about 5 years. I decided to upgrade to a router that supported 1Gbps download speeds. I plan to upgrade sometime this year since my ISP recently finished infrastructure in my area for it. I have been so disappointed with the WIFI capabilities of this router that I'm considering selling it and buying another brand like Linksys.
michaelkenward
Mar 25, 2022Guru - Experienced User
Regardless of their advertising spiel, next to nothing will come anywhere near that with wifi, especially the AC1600 wifi technology in the R6260.
This might be useful:
Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
@duckware knows their stuff and can bust a few myths and cut through marketing hype.
You won't get much for ÂŁ46.75, the Amazon price for the R6260 in the UK. You can spend getting on for ten times that price for a router. Scary.
You say you have a "Arris 1Gbps modem", but that could mean anything. Arris sells a lot of stuff with that label. Only a model number is any guide to its capabilities. The 1 Gbps is probably the LAN speed.
- Angelo22Mar 26, 2022Aspirant
The modem in question is an Arris Surfboard SB190 which only has DOCSIS 3.0 speeds. After doing some research, it turns out I'm only limited to about 644mbps according to the specs. Definitely guilty of just reading the front of the box and a handful of Amazon reviews before buying. Oh well. I can see how marketing can sometimes get people into buying the wrong thing. Don't think it matters much though. I can probably opt to get the 500mbps plan and still get decent speeds. I don't have a real use for anything faster than that, I guess I just wanted to "future proof" my purchase đ
- michaelkenwardMar 26, 2022Guru - Experienced User
Forget about speed meters and "go-fast stripes". Ask yourself, "Is it fast enough for what I want to do?"
If so, throw away those worry beads and get on with life.
