ingyn
Jan 14, 2021Follower
R6260 wont except serial number
Went to regesiter my new router wont take serial number. Its the number thats says serial number below it
No1Mportnt
Jan 14, 2021Luminary
Do you get any kind of error messages when attempting to register the modem? Is there a link at the site to use if you are having issues registering your device? If there is try using that link. You might also try contacting support directly.
