mjh135
Feb 03, 2017Aspirant
R6300 as a WAP using the C7000 Cable Modem/Router
I recently upgraded to the C7000 Cable Modem / WiFi Router and want to use the R6300 WiFi router I replaced as a WAP. I am having trouble setting this up and logging into the R6300 to configure it a...
- Feb 06, 2017
Hi mjh135,
You can check the steps provided on page 100 of the user manual linked below.
http://www.downloads.netgear.com/files/GDC/R6300V2/R6300v2_UM_20May2015.pdf?cid=wmt_netgear_organic
Dexter
Community Team
TheEther
Feb 03, 2017Guru
Do you have a R6300 or a C6300? Your post mentioned both. If you have an R6300, then you can enable AP mode in ADVANCED > Wireless AP. The onscreen instructions should be self-explanatory.
mjh135
I have the R6300. Thanks
- DexterJBFeb 06, 2017NETGEAR Moderator
Hi mjh135,
Dexter
Community Team
