tmgrood
Jul 15, 2016Aspirant
R6300 Bridge Mode Wifi Settings
I have the wireless settings on my main R6300 router to go off at midnight each night. I am planning on setting up my second R6300 in bridge mode in another room connected via Lan to Lan. These are b...
- Jul 16, 2016
HaHa. My bad.
Yes, I will be connecting the two routers using an ethernet cable which is an AP set up rahter than Bridge Mode. Never realized that until you mentioned it.
I will go ahead and close this thread out and set the second router in AP mode and manually disable the wireless signal at the time I choose.
One other quick question though, Is it Lan to Wan or Lan to Lan for AP mode setup? I see pictures of Lan to Wan but have read where Lan to Lan is used.
Thanks.
TheEther
Jul 15, 2016Guru
When you say that your second R6300 is connected via LAN to LAN, does that mean that it is connected to the first R6300 via Ethernet cable? If so, that is not typically how bridge mode is used. That is more typical of an AP setup.
OTOH, if the second R6300 is connecting wirelessly to the first R6300, then shutting off wireless on the first R6300 will not shut off wireless on the second, but the second will be effectively stranded.
In any case, if I'm not mistaken, the settings to "disable" the wireless signal do not shut off the physical radio; the router merely drops all Wi-Fi connections. I mention this because some people concerned with EM emissions expected the radio to fully shut off.
tmgrood
Jul 16, 2016Aspirant
HaHa. My bad.
Thanks.
