tmgrood
Jul 15, 2016Aspirant
R6300 Bridge Mode Wifi Settings
I have the wireless settings on my main R6300 router to go off at midnight each night. I am planning on setting up my second R6300 in bridge mode in another room connected via Lan to Lan. These are b...
- Jul 16, 2016
HaHa. My bad.
Yes, I will be connecting the two routers using an ethernet cable which is an AP set up rahter than Bridge Mode. Never realized that until you mentioned it.
I will go ahead and close this thread out and set the second router in AP mode and manually disable the wireless signal at the time I choose.
One other quick question though, Is it Lan to Wan or Lan to Lan for AP mode setup? I see pictures of Lan to Wan but have read where Lan to Lan is used.
Thanks.
TheEther
Jul 16, 2016Guru
Netgear's official instructions state LAN to WAN. I usually advise LAN to LAN because it's faster but some people have reported difficulties logging into the AP in order to change settings. If you don't plan on changing settings often then it may not be an issue. OTOH, you may not notice any speed difference with LAN to WAN. Experiment and choose what works for you.
- tmgroodJul 17, 2016Aspirant
Thanks for all your guidence TheEther. You have really helped out a lot and I appreciate it.
I think I will go with the Lan to Lan option, make a few wireless settings changes and leave it be after that.
