Funduboy
Aug 01, 2021Follower
R6300 firmware : unbrick
 Hello     I'm using the router since 2012. Recently ; I attempted to upgdate the firmware and I think used incorrect firmware .  Since then the router stopped working. Only power light is ON. Not pro...
Aug 01, 2021Guru - Experienced User
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
