llandyw
Aug 19, 2022Aspirant
R6300 full reset
I have an R6300 that I need to do a full reset on. By full, I mean not just usernames and passwords (which has already been done), but settings as well. The regular full reset doesn't turn back ...
wcalifas
Aug 20, 2022Prodigy
To do a full reset you need to press the reset button with a paper clip for 30 seconds while its powered on.
michaelkenward
Aug 21, 2022Guru - Experienced User
And look at the lights on the thing.
They will do a "disco show" that tells you that it has reset and is restarting itself.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
That says seven seconds, but wcalifas is right in suggesting longer than that.
