GADad
Nov 21, 2020Follower
R6300 Incorrect Password
I have had the R6300 Router for about 3 years with ZERO problems. About 18 months ago I hooked up an LG OLED 55*PUA flat screen to my network using the Netgear R6300. It has run perfectly until 24 ho...
michaelkenward
Nov 22, 2020Guru - Experienced User
GADad wrote:
All my other wireless stuff is working fine, just the LG TV is out and I'm at a loss. Any suggestions on how to solve this??
They smells suspiciously like the TV is the source of the problem.
Is there a way to reset that and start from scratch?
how to connect lg smart tv with wifi - Google Search
