thetimelord's avatar
thetimelord
Follower
Jan 17, 2017
R6300 lost wifi connection and will not connect, light on front panel off, help
my netgear R6300 lost wifi suddenly and won't reconnect, need instructions on how to correct problem
  • DexterJB's avatar
    Jan 19, 2017
    Hi thetimelord,
    Try pressing the WiFi on/off button on the right side (top button) then check if the WiFi LED (3rd light from left) lights up.
    Dexter
    Community Team
