pgilliam
Feb 07, 2017Aspirant
R6300 not detecting Ethernet connection
model: R6300 Suddenly the ethernet stopped on unit. I have tried 2 different ethernet cables, both good, and I have tried plugging in to every port on the back with no response. I have reset the...
- Feb 09, 2017
Hi pgilliam,
1. Please try performing a loop back test to check if the ports still work. You can check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/28408
Note: you can check the Internet light for the model of your router.
2. If the loop back test shows that the ports still work, please check if the connected device on one/any of the LAN ports still get a valid IP address.
3. If it still does get a valid IP, you can try re-flashing the firmware of the router then reset and reconfigure it. You can check the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
pgilliam
Feb 27, 2017Aspirant
For some reason, I have to reset my router alot!
DexterJB
Feb 28, 2017NETGEAR Moderator
Hi pgilliam,
1. Does the Ethernet connection still continue to drop?
2. If you have not done it yet, you can re-flash the firmware of the router.
3. Did the loop back test come out okay?
Dexter
Community Team
- pgilliamMar 04, 2017Aspirant
Every morning I am offline. The loop back instruction was successful. I can't figure out how to find an update. R6300v1 or v2? I find the support page is not very user friendly. Where do I find the re-flash option?
- DexterJBMar 05, 2017NETGEAR Moderator
Hi pgilliam,
If the loop back test showed that the ports work then you can try re-flashing the firmware of the router. First, make sure you know the correct version of the router as indicated on the label (has v2 for version 2, just R6300 for v1). You can check the links below on how to re-flash and reset the router.
Dexter
Community Team
- pgilliamApr 03, 2017Aspirant
Constantly have to reset wireless network adapter
- DexterJBApr 05, 2017NETGEAR Moderator
Hi pgilliam,
1. Is the Ethernet connection working fine now?
2. Is the issue with the wireless connectivity?
3. You can try changing the wireless channel.
Dexter
Community Team
- pgilliamApr 06, 2017Aspirant
Wireless connectivity
How to change wireless channel?
ethernet from modem to router works fine
several times a day i have to reset my wireless adapter
