AsafDayan's avatar
AsafDayan
R6300 set to Bridge mode, which work fine, but now it set wireless to off.
Hello: I set up my R6300 into a bridge mode, which works well on the LAN(solved my initial problem; which I wasn't able to Remote Desktop between to seperate subnets); however, when I logged into t...
  • antinode's avatar
    antinode
    Aug 27, 2018
    > > R6300 [...]
    >    Plain/[v1] R6300 or R6300v2?  Firmware version?
       Still wondering.
    > [...] 1. I have to connect between two buildings, [...]
       If that set of gizmos acts like a long Ethernet cable (which is how
    it sounds), then what you want at the second site may be a wireless
    access point (instead of a full-function router or a router-as-bridge).
    > [...] connected to the second router NetGear R6300.
       When dealing with devices which have multiple Ethernet ports, it's
    helpful to specify which port on each device is connected to which port
    on the other device.
       I'll assume that the radio gizmo at the main router is connected to a
    LAN Ethernet port on that router, and the remote radio gizmo is
    connected to the WAN/Internet Ethernet port on the second router.
    > 2. It works very well, [...] two different subnets. [...]
       That's what happens when you cascade two of these routers.
    > [...] due to different subnets I could not remote desktop between PC1
    > to PC2.
       There's actually a way to make that work, but a better (simpler?) way
    would be to configure the remote router as a wireless access point.
    That should give you one big LAN with one subnet.
    > 3. In order to solve the issue(which I did), I configured the NetGear
    > R6300 in a Bridge Mode. [...]
       I think that that was a fluke.  "Bridge Mode" is intended to use the
    remote router's wireless-network radio(s) to communicate directly with
    the main router, as if it were a wireless client device, not a normal
    router.  As I understand it, you want to use the simulated-Ethernet
    radio gizmos to connect the two routers, not their built-in
    wireless-network radios.
    > 5 I acomplished what I needed; however, the R6300 that is set to a
    > Bridge Mode, show that the wireless is off [...]
       Bridge Mode dedicates the remote router's wireless-network radio(s)
    to communication with the main router, which may really be doing nothing
    in this case, because the main router is too far away.  A side effect of
    Bridge Mode is (apparently) to disable the router's router functions,
    much as would happen if you configured it as a WAP.
    > So the qouestion is, when the NetGear R6300 is set to a "Bridge Mode
    > (as described ablve)" can it support wireless? [...]
       No.  If you configure the remote R6300 as a WAP, then you should get
    the desired effect.  Again, the R6300-as-WAP gets stupid (no router
    functions), but the wireless-network radio(s) will continue to operate
    normally, supporting nearby client devices, rather than trying to link
    back to the main router.  (Your fancy radio gizmos will be linking the
    two routers.)
       If you have an R6300v2, then look in the User Manual for "Wireless
    Access Point (AP)".  As I read the User Manual for an R6300[v1], it
    seems to lack the same one-step WAP-mode option, but there's a pretty
    universal procedure which should be able to do the job:
          https://community.netgear.com/t5/x/x/m-p/1463500
    That's written for a Netgear C6300, but the steps are about the same for
    any other router (any make/model) which lacks a one-step WAP option.
       What could go wrong?
