sunnyoc
Apr 28, 2017Aspirant
R6300 v1 Cannot Connect Directly to Cable Modem Anymore
I had used a R6300 v1 router with an old cable modem, Motorola SB5100, for over 4 years without any problem. A couple of weeks ago, the internet LED on R6300 went out. I thought it might be an et...
- May 01, 2017
Hi sunnyoc,
Try MAC spoofing on the R6300. Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/1086
Dexter
Community Team
sunnyoc
Apr 29, 2017Aspirant
Yes, I did all these.
William10a
Apr 29, 2017Master
Any lights lighting up on the router and you are getting internet if you connect a computer direct to the modem right?
Try this plug the lan from the modem into any free lan port on the router and see if the light lights up for that port if so you could have dead internet port if not a possible bad lan cable. I know the router will not use the lan port as internet but the switch in the router should act like a network switch and pass a signal to the other lan ports of the router under netgears firmware.
If you can make your lan cables you can make a test plug for your lan ports take a rj45 plug and wire pin 1 to pin 3 and pin 2 to pin 6 this be enough to operate at the 100mb (orange collor) on the lan port it is pluged into.
- sunnyocApr 29, 2017Aspirant
The original yellow ethernet cable that came with my R6300 router was broken for sure. When I used it to connect the internet port on R6300 to my cable modem, the internet LED on the R6300 router was off. Of course, there was no internet connection on R6300's LAN ports and WiFi.
I have another good ethernet cable. I used this one to connect the internet port on R6300 to my modem, the internet LED on the R6300 was on, but stayed in amber color, not the green color. Again, I had no internet connection through the R6300.
I used an old and functional 54G router to connect to my cable modem. I had internet on all LAN ports of this router and on 54G WiFi. Then, I connected the internet port on R6300 to one of the LAN ports on 54G router with the good ethernet cable and the internet LED on R6300 became green. I had internet on all the LAN ports and on WiFi on R6300 this way. Of course, I don't need two WiFi signals. I turned off the WiFi function on the 54G router. The 54G router basically acts as a switch between the R6300 router and the cable modem.
Very strange. I don't know what is going one with my R6300.
- William10aApr 30, 2017Master
I wonder if the isp did a firmware update on the modem and now the router and modem disagree now and have you check to show if the r6300v1 has a firmware update on netgear to a newer version?
- DexterJBMay 01, 2017NETGEAR Moderator
Hi sunnyoc,
Dexter
Community Team
- DexterJBMay 07, 2017NETGEAR Moderator
Hi sunnyoc,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- sunnyocMay 29, 2017Aspirant
I bought a new cable modem, Arris SB6183, to replace the very old modem. Now, the R6300 works beautifully with the new modem.
Still I could not figure out why my R6300 suddenly stopped talking to the old modem.
