MDSTEWART1
Jul 21, 2022Follower
R6300 V2 POWER SOLID RED
The power led is sold red i have reset and done everything i can find online. Still nothing. Is it fried? Thanks for your help in advance.
Jul 22, 2022Guru - Experienced User
You tried a factory reset? Pushing and holding reset for up to 30 seconds while its powered on?
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
