DavidO
Feb 11, 2017Aspirant
R6300 WiFi not enabled, even after configuration
Hey guys, I got this router used from eBay and am unable to get the WiFi working. The ethernet cord through the router works though. I've tried spoofing a MAC address with my computer's. The firm...
- Feb 11, 2017
No indicator LEDs for radios? Did you enalbe the radios when you configure the router?
Tried resetting the router?
DavidO
Are you referring to WiFi when you say radio?
DavidO
I've done several reboots and finally, the interface showed the options to enable radios. Hopefully this router won't continue to be temperamental like this. The ethernet and WiFi work now, although the LED light doesn't come on. Should I be concerned?
Thanks for the help!
EDIT:
My fears of it being temperamental were correct. It isn't working anymore. I'm just going to return it to the user and give them a bad rating on eBay.
