RedRaspberry
Jan 13, 2018Guide
R6300 wired computer cannot see wirelss computers
Sometime in the last couple of months I lost the ability to connect to my laptop on the wireless network. The laptop can see the desktop mapped drives through the wireless network.. I have tried...
- Jan 14, 2018Permissions on sub-folders do NOT necessarily inherit the permissions assigned in parent folders. You may have to explicitly enable sharing on the Desktop folder. Anyway, I suggest you take this to a Windows forum where you may be able to get expert help.
TheEther
Jan 13, 2018Guru
Did you enable the setting in Windows to make the laptop discoverable?
RedRaspberry
Jan 13, 2018Guide
Yes, it has been working for a couple of years but somethig just stopped it. I can see an icon for the latop in the Network pane. But get an error when I truy to see the laptop.
- TheEtherJan 13, 2018GuruDid you update Windows on the laptop recently? One of the major updates, like the Fall Creators Update, may have reset things.
Can you ping the laptop from the wired machine? If yes, then the router is definitely not the source of your problem.- RedRaspberryJan 13, 2018Guide
I update whenever they come . I cannot ping the laptop from the desktop.
- TheEtherJan 13, 2018GuruWell, then you should go back and check the settings on the laptop. I assumed that you are running Windows 10, but if you are running Windows 7, then the sharing settings are a little different. Frankly, I don't have a Windows 7 machine any more, but I believe it has a similar setting to make it discoverable.
If the laptop is running any third-party security software, like Kaspersky, Symantec, etc., then you should check those settings, too.
Do you have any other routers or networking gear in your setup, or are all of your devices connected directly to the router?
Could your laptop, by any chance, be connected to the R6300's guest network?
Are the IP addresses of the laptop and the wired computer on the same IP subnet? Can you provide them? There's no harm sharing them; they're private IP addresses.
