CyberCoach
Nov 28, 2016Aspirant
R6300 Wireless Speed Drops, Requires Hard Reset to Restore
Need some help. I have an R6300v1 running latest firmware v1.02.2.78. Noticed wireless speeds on 2.4 and 5.0 below 1 Mbps. I connect to internet at 100Mbps +. I'm using Speedtest.net. Once it...
- Dec 21, 2016
Please consider this problem closed. The relaod and reset to default was performed and since then there has been no issues.
Thanks agian for quick, professional help.
CyberCoach
Dec 01, 2016Aspirant
Got side tracked. Okay, manual flashed my router with latest firmware and set my options.
The monitoring begins.
Thanks for help.
DexterJB
Dec 04, 2016NETGEAR Moderator
- CyberCoachDec 05, 2016Aspirant
Still a little earlyt osay but it is very positive. The network speed has been sustained, wirelessly, since I manual reloaded firmware as per your instructions. If I don't see a reoccurence this weak I will mark this solved.
Interest that a reset alone wouldn't fix.
Thanks
- DexterJBDec 05, 2016NETGEAR Moderator
- CyberCoachDec 21, 2016Aspirant
- DexterJBDec 22, 2016NETGEAR Moderator
