OlyG
Oct 07, 2017Aspirant
R6300v2 -- Bad Firmware on Netgear site R6300v2-V1.0.4.12_10.0.77.chk
Guys BEWARE that The latest October 2017 firmware for R6300v2 is bad. I had manully download 'R6300v2-V1.0.4.12_10.0.81.chk' and the router stopping issuing IPs and turned into a brick. Now I can...
- Oct 08, 2017
Do you mean that even after a factory reset you cannot access the device?
If so, you may not have reached the end of the road.
First try this:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If that fails, move on to this:
How to upload firmware to a NETGEAR router using TFTP | Answer | NETGEAR Support
michaelkenward
Oct 08, 2017Guru - Experienced User
First try this:
OlyG
Oct 11, 2017Aspirant
Thank you Micahel. Initially I did the reset as described, but it didn't help. In fact's that's when I lost total control of the device probably becuase it won't even issue an IP after the reset and using admin and default password it came with.
I went to Costco an bought a new router. Couple of days later I was playing with the above device and it worked this time.
Thank you again for your post though.
