StarkmanAlive
Mar 19, 2019Aspirant
R6300v2 - Can I restore settings after firmware update?
Greetings all,
I'll be doing a firmware update to our R6300, and I've already made a backup of the settings (which only contains simple stuff like security settings and password stuff). After t...
- Mar 19, 2019
> [...] my router was issued by my cable company, and it doesn't allow
> updates (they said they do auto updates, but who knows).What's your "my cable company"? What's the actual firmware version?
If it has a "CH" suffix (or similar), then that would be consistent with
ISP-specific firmware ("CH" for Charter).There have been efforts to replace such ISP-specific firmware. See,
for example:https://community.netgear.com/t5/x/x/m-p/1543374
But, if you're still using that ISP, then replacing the firmware
behind their backs could be unwise. If you just bought a used R6300v2
for general use, then using generic firmware might make more sense.
StarkmanAlive
Thanks for the input. I had forgotten to mention that the instructions say to do a factory rest (thus wiping out my settings) after installing the firmware update. Additionally, I can't do a update anyway, so I've found out; my router was issued by my cable company, and it doesn't allow updates (they said they do auto updates, but who knows).
We'll thanks again.
We'll thanks again.
antinode
Mar 19, 2019Guru
for example:
- StarkmanAliveMar 19, 2019Aspirant
Yeah, it's charter, and yeah, it has the CH suffix. So, I'll be leaving it alone.
