algox
May 19, 2017Aspirant
R6300v2 - Firmware 1.0.4.8_10.0.77
Local network devices unable to ping or see each other. Breaks existing applications and wireless printer fails. After applying the update I noticed that the router is operating is isolation m...
- May 24, 2017
Hi algox,
You can try re-flashing the firmware then do a factory reset. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
michaelkenward
May 19, 2017Guru - Experienced User
algox wrote:
After applying the update I noticed that the router is operating is isolation mode. I don't mind the isolation mode but need to make certain local ips "pingable".
Did you do a factory reset after the firmware flash?
It isn't always necessary but it is the first thing to try if anything goes wrong.
algox
Yes I did a factory reset. All of this happened only after applying the update.
- michaelkenwardMay 19, 2017Guru - Experienced User
Did you reset after the update?
It isn't clear from your answer.
- algoxMay 19, 2017Aspirant
Yes I did a factory reset after applying the update, per the updates instructions.
