algox
May 19, 2017Aspirant
R6300v2 - Firmware 1.0.4.8_10.0.77
Local network devices unable to ping or see each other. Breaks existing applications and wireless printer fails. After applying the update I noticed that the router is operating is isolation m...
- May 24, 2017
Hi algox,
You can try re-flashing the firmware then do a factory reset. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
algox
May 20, 2017Aspirant
I noticed a couple things:
- When logged into router I can't see ips of devices connected. Only happens on 2.4GHz.
- If I switch to 5GHz I can see device ips and I can ping other devices on network. Everything works as expected.
The problem is not every device is able to connect to 5GHz wireless network. So how I can downgrade and install previous firmware? Is there a website listing all firmware versions?
Thanks.
DexterJB
May 24, 2017NETGEAR Moderator
Hi algox,
Dexter
Community Team
- algoxMay 25, 2017Aspirant
Not sure if re-flashing was the answer or doing factory reset via button instead of using link in admin panel. Or perhaps turning it off and on again but it's working now. Thanks!
