SaintGrimm's avatar
SaintGrimm
R6300V2 Bridge Mode Prevents Port Forwarding! Help!
I have spent over a total of 100 hours trying to get port forwarding to work on my network so that I can use the remote access feature on the Plex Media Server app.   I've done all the basics, rese...
  • StephenB's avatar
    Feb 01, 2017
    That's it!
    Your internet port has a 100.x.x.x address.  canyouseeme.org shows a 76.x.x.x.
    That says that either your ISP's modem is doing its own NAT routing or that your ISP is using carrier NAT.  On paper at least 100.x.x.x is reserved for carrier NAT.
    See if you can find the manufacturer/model for that modem.  You also might need to contact your ISP, and see if they have some way to keep that port open.
    Another thought is that you could try changing the port number (say to 49152) in the R1 forwarding rule and also in the plex server configuration.  It's possible that using a port in the "private use" range will work better.
